just-in-time (JIT) debugging...a l'aide
Postez dans ce forum vos questions concernant les navigateurs internet (Internet Explorer, Firefox et les autres)
manu
Message par manu » 13 mai 2010 23:35
je suis nouveau et cherche de l'aide.
Depuis une semaine j'ai le message suivant qui s'affiche lorsque je fait une recherche via internet.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at IEToolbar.Toolbar.insertMenuItems()
at IEToolbar.Toolbar.Toolbar_Load(Object sender, EventArgs e)
at System.Windows.Forms.UserControl.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
WalterShop
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WalterShop/1.4.0.0__4b827ebe229d539f/WalterShop.dll
BandObjectLibrary
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/BandObjectLibrary/1.0.0.0__4b827ebe229d539f/BandObjectLibrary.dll
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Interop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Interop.SHDocVw/1.1.0.0__4b827ebe229d539f/Interop.SHDocVw.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Quelqu'un pourrait il m'aider s'il vous plait :?:
Cordialement
Emmanuel
Re: just-in-time (JIT) debugging...a l'aide
Message par Steph » 14 mai 2010 00:01
Bonsoir manu,
Commence par faire une restauration du système à une date antérieur (plus d'une semaine dans ton cas) en t'aidant de ce tuto ---> Utilisation de la restauration système
Sinon tente de désinstaller puis réinstaller Microsoft .NET Framework 2.0
Procède comme suis :
  1. Désinstalle d'abord celui-ci que tu as
  2. Redémarre ton PC
  3. Réinstalle celui-ci que tu as téléchargé
  4. Et redémarre une nouvelle fois ton OS
Retourner vers « Navigateurs »
